Hi all.
does anyone have experience/knowledge on building tools for milling/turning?- preferably 3d tools to be used in Vericut later on.
also any info on eccentric turning sequence would be great.
Tool library Mill Turn machine & eccentric turning sequence
Hello Nir,
maybe if you could specify your questions regarding eccentric turning sequences a little more, it will be easier for someone to assist.
Usually "eccentric" refers simply to workpieces that are not rotational symmetric about the machine axis, like for instance when turning a section of a crank.
So the whole process itself doesn't look different from the Creo side, just the location of the workpiece and hence it's rotational axis is eccentric to it's principle axis.
Gunter
