Turning and Vericut
PeterBrown
Turning and Vericut
Hi all,
I'm having some teething trouble with ProNC turning and Vericut. Can anyone help me with the following issue (as I see it)?
When using Vericut with a turning mfg the folllowing occurs in Vericut's Tool Manager:
1) A parameter tool that is not used in a sequence is output with the control point at the center of the nose radius
2) A parameter tool that IS used in a sequence is output with the control point at the intersection of the insert's edges (hint: this is correct I think)
3) A solid tool is ALWAYS output with the control point at the center of the nose radius (hint: this is incorrect).
Am I missing something?
Regards
Peter Brown
NC Programming Manager
Jarvis Products Corp
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
