I'm trying to help out a tooling guy by giving a tool path upon a flattened sheet. The part is roughly cylindrical so I have flattened the surface sheet and flattened an offset sheet which is at the tool depth. It is a simple matter then to project the graphics at the surface to the flattened sheet at the tool depth. The problem then is how to wrap these graphics back to the model. So far, I have tried curves, cosmetic sketches, datum curves and sketch curves. The bend solid (flatten curves) doesn't seem to recognize any of these curve selections and simply "hangs". Is the "flatten curve" command a one way street just for taking a curve off the model and putting it on a flattened sheet as I am looking to do the exact opposite? Maybe one of the "label" experts could help me out here; all suggestions would be gratefully received.
WF3.0 M160
Richard A. Black
Lead Engineer
Eaton Corporation
16900 Aberdeen Road
Laurinburg, NC. 28353
Tel: 910-610-1788
Fax: 910-277-3700
Richard, There is info here on a Sheetmetal function that allows a projected curve to be flattened when a Sheetmetal part is flattened. This may be a technique you can consider.
Preview file
12 KB
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
