Using Pro NC in Creo 2???
jeuclide
8-Gravel
Does anyone know how to get Creo 2 Pro NC module up and running? The old way was tools/Floating_Modules can't seem to figure it out in Creo 2. Also is there any enhancements to the tool anyone knows about?
Jeff
SteveLucas
(To:jeuclide)
Jeff,
they have changed how it works. Now you have to go to the file pulldown then the licensing near the bottom then you can add floating modulesby refreshing the list.
I will work on showing something for you to load them in the setup so you don't have to do it each time you start Pro E.
Steve
SteveLucas
(To:SteveLucas)
Jeff,
Sorry missed a step shoulde be file pull down then options then licenseing then refresh the list.
You did it again!!! Thanks Steve!! I will skunk you one of these days!!!
Jeff
