Hey guys..
I have a strange problem.
Sometimes when creating a mill volume path , it can´t be mill because the mill volume suddently disappears.
I´ve had this problem a couple of times , but not every time.
I make the seq , choose the volume (which appears in solid) , and everything seems okay. But when i try to play the path , the volume is gone.
You can still see it in the modeltree , but not select it on the model..
In this case i´ve fix it with a mill vindow , but still real frustrated..
Have anyone had similar problems ?
You had me confused for a few minutes ![]()
i had to go into the seq setup and add the top surface as the "top surface"
Yes I have had this problem what i found is that if you go to
VIEW
VISABILITY
UNBLANK
OK
it will unblank your volumes ![]()
Still the same problem..
I can see the volume , but not select it 😞
Try make a volume path on my attached part , and you will se the problem...
Hey Nick..
Thank´s a lot , THAT help me out 🙂
I´ve never used "top surfaces" before...
I thought that it by default , will mill parralel to the retract plane.
Hey Jesper,
This is just one more of Pro/NC nasty bugs... I know it since WF2.0
They are too busy making Pro/NC far better than the competition... :sarcasm:
Daniel
