ZIG-ZAG without returning
C_Spagnolli
I want to run the toolpath as in the attached video (contorniture.avi) but using volume roughing or other, "not trajectory" because I want to use the STEP_OVER.
Photo example volume
2 REPLIES 2
Cannot see your video. Maybe you could just post a picture of the path you are wanting to create.
Custom trajectory will let you use step over for profile cutting. That might be the only way to do what you want to do. Particularly if you are trying to make the path as efficient as possible to reduce time, etc.
C_Spagnolli
(To:KenFarley)
These are 3 photos to see the toolpath I would like to use
I try to reload the video
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
