abs accuracy value for plastic parts/mold design/machining
al204
Hello ProE users...
I have a question concerning the abs accuracy parameter that I should use to model plastic parts and the molds that will be designed after them.
What value are you currently using?
At the moment I´m using 0,0254 mm (0,001 inches). Is this tolerance too high??
So far I have had good results with this value, I just want to know what most of you out there are using and why.
thanks, best regards
AL.
DWF
(To:al204)
Alvaro,
A guru once taught me to always try to model at an absolute accuracy of 0.0001" because most nc machines work to 4 decimal places. Ithas always worked good for me. Also when you are using Mold/Cast to build plastic molds, that accuracy will insure that you don't have trouble.
In Reply to Alvaro Barboza:
Hello ProE users...
AL.
