approaching a milling window
al204
Hello...
How can I make a tool approach a milling window from a specific direction?
I have tried using approach walls but they are being ignored..are there any guidelines on how to use them??
please look at the image below
thank you
al.
In Reply to Alvaro Barboza:
Hello...
thank you
al.
Hey!
I`m not sure about the mill window cause i don`t use it much,but if you make a mill volume the approach walls will NOT be ignored.
