can creo manufacturing and programming is run on siemens controller vmc machine ?
PTC provides some sample postprocessor files (Siemens 840 and 810D) but for something more specific you should contact Austin NC.
Austin N.C. - Mill Postprocessor Library
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS54723
Can anybody help me in getting Post processors for HAAS VF4 (HRT210 - 4th Axis) and HAAS ST20Y (Turn mill)?
Your help is highly appreciated.
email: vsnprasad.k@mechoptronix.com
Thanks in advance.
Adding a bunch of posts onto existing discussions from 6 years ago isn't going to help you much. The only reason I saw this was I was looking for an old post of mine as a reference. Sidetracking a discussion about a specific topic is not something people like.
You'd be better off starting your own discussion, or maybe using any of the many search engines available to look for a post processor. There have been countless discussions of post processors in the past, maybe one that is pertinent to you.
