Is it possible to get Pro/E to output a circular pocket command? I'm only familiar with Haas, which on those machines is a G13code, for CCW (G12 for CW). I can only seem to spit out G03 for CCW.
Thanks in advance.
Jeff
Hi Jeff,
Yes you can do it... you will have to write so FIL code on your PP to catch up special commands that you are going to generate using a MUDF that will handle this for you...
Drop me a line and we can discuss the details...
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
