i'm little new to creo
so anybody plese explain me how i can integrate vericut into creo 2.0
i have already install both softwears but when i run nc check it gives "Application VERICUT_DLL is not available or supported on this platform."
It sounds like you haven't installed the vericut option.
you need to run the set up disk again but select reconfigure.
when you come to this screen
select the customise option
then you need to search throught the opptions on this screen and selecet the vericut option to install
You need to complete the reconfig process, then you shoul have the Vericut.dll
Peter
What version of Creo are you using? PTC dropped Vericut for Moduleworks.
https://community.ptc.com/t5/Additional-Creo-Questions/ModuleWorks-to-replace-Vericut/td-p/169907
