The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
emx_comp.rel file
sammy1994
11-Garnet
emx_comp.rel file
what is the use of emx_comp.rel file?
Please provide some documentation for the same?
3 REPLIES 3
tschneyer
6-Contributor
(To:sammy1994)
Hello sammy,
you can download our tutorial and you will find a section which describes the emx_comp.rel file.
Basically, you can use the emx_comp.rel file to write relations to all components that are assemble with EMX.
https://community.ptc.com/t5/Manufacturing/Expert-Moldbase-Extension-10-Tutorial-for-download/m-p/604966#M4438
Kind Regards
Thomas Schneyer
B&W Software GmbH
Thank you for your response!!
Can you please tell me if it is possible to use that file to add some data to the BOM.
For ex: specifying the material parameter of screw in the .rel file so that it gets updated in the BOM.
I tried doing it but was unsuccessful
tschneyer
6-Contributor
(To:sammy1994)
if you set up a relation that fills the content of a defined EMX Parameter, the parameter value will be visible in the BOM.
Kind Regards
Kind Regards
Thomas Schneyer
B&W Software GmbH
