g2 and g3 codes
Mickyd1
g2 and g3 codes
Hello everyone
im a fairly new user to pro e had it 3 months now im having a problem that when i generate the nc file when it generates the g3 or g2 code with i and j code if i take more than 1 cut the i and j code are mising, if i just take the single cut the i and j are there. im using pro e 5 and creo 1.0 any ideas would be gratefull
I'm guessing this is the area to focus on
You are going to need to look at your post processor. In the Applications - NC Post Processor
Mickyd1
(To:Mickyd1)
thanks nick seems to work
