Hello everyone
im a fairly new user to pro e had it 3 months now im having a problem that when i generate the nc file when it generates the g3 or g2 code with i and j code if i take more than 1 cut the i and j code are mising, if i just take the single cut the i and j are there. im using pro e 5 and creo 1.0 any ideas would be gratefull
You are going to need to look at your post processor. In the Applications - NC Post Processor
I'm guessing this is the area to focus on
thanks nick seems to work
