gpost startup "without pro maufacturing"
cncwhiz
Is there a way to open up the built in gpost without opening pro manufacturing?
Terry,
You cannot run G-Post or the Option File Generator, that comes with Pro/NC,
with out having Pro/NC running. It uses the Pro/E license. The only way to
use G-Post outside of Pro/NC is to purchase a standalone version.
If you are interested please contact me directly.
Fred Nemecek
Austin N.C., Inc.
512/458-1112 x19
_____
In Reply to Fred Nemecek:
Terry,
I think it is nit exactly true.
You can actually run Option File Generator with the follwing command progpostq -sy:2 without Pro/E running.
Daniel,
You are correct that you can run the Option File Generator with out having
Pro/NC running or a license checked out. To process your tool path through
a post you must have Pro/NC running.
Sorry for the confusion!
Fred Nemecek
VP Product Development
Austin N.C., Inc.
512/458-1112 x19
_____
