Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
In creo 9.0.4.0, 540*160*5mm size, use mill window + volume rough with Diameter 8mm tool, and then followed by local milling with Diameter 4mm tool to remove residual material ( with pre-sequence in local milling ) , it takes 7 hours to complete path calculation, it is hard to continue my job. any comments for this issue? are any parameters wrong used in local milling?
For a part like this, with many identical pockets, the usual technique is to do an individual pocket tool path, and then array it.
Roughing tool paths can use a loose tolerance if necessary.
Thanks Bmuller,
I will take your advice, as for loos tolerances, it will affects Roughness of surface area.
