I am using Creo Parametric - Release 8.0 (connected) Release 8.0 and Datecode8.0.2.0
is there a way to add a view in material removal simulation? i would like to be able to see the front and back of the part at the same time like vericut.
This is not part of ModuleWorks within Machining of Creo Parametric. To request this functionality, refer to Product Ideas @ PTC Community
