I am experiencing issues with the material removal simulation in creo parametric 10.1, where the play path changes the tools I imported. I imported the following tools: H63TH-SVVBN-H16 with a VBMT160408 and MTJNL2525M16N with TNMG160408L-ES.
During the play path simulation with the VBMT insert, it remains and shows the correct path. However, when attempting to use it in the material removal simulation, Creo modifies its geometry, resulting in an error. Additionally, I am unable to utilize the toolholder for generating the collision report.
