Hello, everybody,
Does anyone meet the problem when saving the part file to step, the lattice design is missing?
For example, in the first picture, I created a lattice structure, I then saved it as step file.
But when I open the step file, it appeared as the second picture.
@FZ_6577930 wrote:
Hello Martin,
Yes, Creo 8.0.
The lattice is diamond.
I have uploaded the model.
thanks,
Feng
Formula driven lattice cannot be exported to STEP.
Please read https://www.ptc.com/en/support/article/cs303867 document.
@FZ_6577930 wrote:
Hello, everybody,
please specify what type of lattice did you create and what Creo version did you use (Creo 8.0.?.0)
... upload your model, if it is possible.
Hello Martin,
Yes, Creo 8.0.
thanks,
Feng
@FZ_6577930 wrote:
Hello Martin,
Yes, Creo 8.0.
thanks,
Feng
Ok, got it. It is sad.
However, it can be exported to stl., not so convinient as to step file though.
Thanks for your information.
