Can't understand how do I put these shrinkage value(see jpeg) on my model.. please any one guide me...0.0050cm/cm
....or 0.0050in/in...????what does it mean
Regards
Asif
Asif, have you tried the following?
Step 1: Open the model of the part that you are tryinig to apply shrinkage to.
Step 2: Click the file drop down tab, scroll down to "Prepare" then clock "Model Properties".
Step 3: Under the "Tools" catagory you will see the value Shrinkage and all the way to the right there is a link that says "change".
Step 4: Once you click on change, you will be allowed to apply shrinkage by either scaling, or by dimension.
I hope this helped, best of luck
regards, Ben.
I would say if you are using millimeters it would be a safe bet to use .050 mm, which would be the same as .005cm.
Usually I use shrinkage by scaling when working with molded parts.
I apologize for the confusion.
Judging from the data I found and the data you provided we can both agree that per imperial units .005 in/in seems to be correct.
Convert and this is what you get.
.005 in/in equals .127mm
Actually, no, shrinkage is a ratio. Both the numerator and denomonator have units, so you have to convert both, but as you'll see it doesn't matter.
0.005 in / 1 in =
0.127 mm / 1 in =
0.127 mm / 25.4 mm =
0.005 mm / 1 mm
Are you asking what the shrinkage values mean in terms of the physics behind it? Basic concepts? Or are you asking how we'd use those values to build a model for a mold?
Regards
Asif
Mold shrinkage is a ratio, the units don't matter. Notice that the value is the same, 0.005, for both metric and English. It's 0.005 inches of shrinkage per 1 inch or 0.005 cm per 1 cm. The same would be true of mm or km or yards or whatever.
What it is saying is that it shrinks 1/2 of one percent. In other words, for each 1 unit of length it will shrink 0.005 units.
