nc g code
yqureshi
nc g code
sir who,s postprossecor in pro-engineer5.0 support herco machine control.
2 REPLIES 2
Yaseen,
I've moved your request to the Manufacturing space as I think you'll have a better chance of a quick reply here.
Good look, I hope you'll find what you need.
KenFarley
(To:yqureshi)
You need to be more specific about what you are dealing with, particularly:
(1) Did you mean "Hurco" as the machine type? You have to also tell people what model and the controller type. I don't know about Hurco, but machines can change controllers from year to year (i.e. we have two machines from the same manufacturer, about two years apart; one has a Fanuc, the other a Mitsubishi controller).
(2) Usually your best bet as a start is to search for the file you're looking for, but to get anything meaningful you'll have to spell it "postprocessor". PTC has a library of postprocessors available, as noted in the responses to this thread: Anyone have 4 Axis post working on Wildfire 3?
I haven't noticed any postprocessor changes between Wildfire 5.0 and Creo, so anything that is used now should be okay for you.
