option file generator
shaanmech
can anyone explain how to create option file in creo2.0?
Can you explain "option file"?
option file is a file about machine control data generated by option file generator in creo2.0
gkoch
(To:shaanmech)
Since the post was filed under manufacturing, we can assume this is about GPOST Option File Generator.
You need to be in Manufacturing mode (requiring a manufacturing license and opening or creating a manufacturing model).
Then you find the Option File Generator (where you can create or modify option files for the postprocessor) under the Applications tab.
