hello everyone
ive been using creo 1.0 for a few months now but have trouble when trajectory milling. when i take more than one cut the plunge feedrate doesnt appear on any cut sfter the first one. the cutter plunges at the same feed as the cut feed rate, am i missing something? trouble is when machining at fast feedrate the cutter plunges too quick.
thanks for any help
mick
Mick,
If you have issues in receiving a reponse, your question might have greater visibility if posted as a discussion.
