post processor tweeks and other issues
cncwhiz
All,
I have some posts that I have done some modifications to. I have a basic understanding of what is going on in the fil file but I am searching for more understanding. I have two areas that I want to work on. Something that I want to do is my spindle roatation looks to be turned off in the spindle area and hard coded in another area. I use an "M13" to turn on the spindle and coolant in the same M code. I want this command to still output when I call for CLW and flood coolant. I want to redo this area in the fil file. I want to be able to use a CCLW rotation for a few of my tools as well as my deburring brushes. I also want to add a "Thru" coolant option. Does anybody have any info and or samples on this issue?
On another subject I wanted to add that the help here as far as sharing posts is pretty good. I have been working with some other shops that do not use pro engineer. The one shop that I am working with uses Mastercam. Finding anybody to share posts for their software is not too good. I am sire that their are other CAM programs with the same problem. I do not want to be the internet cop and ask if they are using a good copy of the program or a "gray" copy. What I am getting at is that I am thinking about hosting a sharing web site for post processors. We have talked about sharing posts in here and it did not go far?
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
