Dear Gurus,
I wanted the tool path generated using surface milling to consist of arc
output in XZ plane and YZ planes. Currently the arc output is only in
the XY plane and proe outputs a series of points instead of arcs in the
other two planes. Is there a method to overcome this?
I use proe WF3 build M010.
Best Regards,
Oliver Coelho.
alfanar Moulds (CAM Dept.)
PO Box 104184
Riyadh 11626
KSA
