pro/nc problem: roughing,re-roughing & gone
ptc-1424846
need help here... at pro/nc when i go into machining roughing & then to re-roughing the system crashes... what's that suppose to mean & how to solve the issue.. thnx..
roughing re-roughing and finishing in pro/nc is a nightmare!!!! If it does not crash (your are lucky) the cnc code need alot of attention!!! That's the main reason that ptc moved to Pro/Toolmaker!!!! If you need high speed machinning use Pro/Toolmaker eitherwise use different strategies (ie volume-surfacing)
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
