Hello...
I have a question concerning the use of a roughing sequence after a volume milling operation.
1. The first sequence is a Volume Mill, using a mill window as manufacturing geometry. This sequence is used for roughing purposes.
2. I try to create a RGH sequence, using the same mill window, to continue the roughing process.
Unfortunately the the second sequence creates a path that removes all the material that was already removed by the first sequence (VOLUME MILL ) , this means it is not recognizing it, it "thinks" no material has been removed.
What can I do?
regards
Al.
