Hello ProE users...
This time I have a question on injection molds. I have been assigned my first design project.
How can I estimate the thickness for the cavity plate? What should be the minimum plate thickness remaining after creating the cavity?
I work at a toolshop, most people here decide what plate thickness to use based on experience, because such thickness has worked before with a similar, etc.
However I need to present the technical argument on which I have based this decision.
I thought of calculating the minimum plate thickness (after creating the cavity) to allow it flexing 0,05 mm under a distributed constant force.
The constant force would be (injection pressure x projected area)...you think this is an educated way to justify such decision?? when you design a mold how do you decide what plate thickness to use?
Unfortunately we do not have a CAE software such as moldflow or moldex 3d. I would be using pro-mechanica for the flexing calculation.
thank you, best regards,
Al.
