"contour re-machine"
PaulWhitten
does anyone know how to produce a toolpath that does nothing but machine corners based on the previous tool size? the toolpath type i am trying to re-create is called a "contour remachine" in Work NC (for anyone with a Work NC background). i can get real close by choosing local milling, by previous tool, then using a mill window to set my boundry, then setting various parameters to get close, but i never quite achieve the "contour re-machine" produced in Work NC. my tool retracts too much and none of the passes are connected.
any help is appreciated
thanks in advance
paul whitten
0 REPLIES 0
