sketch error
岩茉_9843933
2-Explorer
sketch error
I am using Creo Parametric 5.0 5.0.4.0
I'm trying to remove material ina rotating sketch.
Applies at 4 microns, but not at 3 microns.
I don't know the cause.
Is there a way to define it below 3 microns?
I guess it is accuracy problem. Set absolute accuracy and lower its value.
Martin Hanák
Hi, @Martin Hanák
Thank you for your answer !
I try to set abusolute accuracy.  🙂
