tool identification
byron.taylor
tool identification
How do I getmy post to show what type of tool I am using. T01 (3/8endmill)
I can output the tool number, but the description isn't there.
Thanks, Byron
Byron,
The tool comments are PPRINT statements in the NCL file. If you set your
post to output Operator Messages to Tape File you will see them in the .tap
file. This is set in the Option File Generator on the Operator Messages
menu.
Fred Nemecek
Austin N.C., Inc.
512/458-1112 x19
_____
Bryon,
In addition to Fred's comments, you need to configure Pro/NC to output
the tool information to the NCL file (as PPRINT statements).
Each workcell can have a PPRINT table associated with it. You can set
up the PPRINT table to output many different pieces of information in
the NCL file.
You can select which information is included in the NCL file as follows:
[Workcell] Opens the "Machine Tool Setup" window.
[PPRINT]
[Modify] or [Create], as needed.
Select items to include in the NCL file by setting the option to
"Yes".
Dave Ford
NC Programming Mgr.
G.W. Lisk Co.
Clifton Springs, NY 14432
(315) 462-4381
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
