trochoidal milling with 5-axis machining
NiWi95
2-Explorer
I want to use trochoidal milling with 5 Axis machining. Is this function given in Creo 5.0? I added "trochoidal_milling" in the config.pro. After selecting the trajectory milling the two parameters "trochoid_width" and "trochoid_depth appear, where i can configure my milling path. When I switch to 5-axis machining the parameters disappear. Why is this happening? I am using Creo Parametric 5.0. Thank you in advance!
cfardmanesh
(To:NiWi95)
 Well there are bunch of things here. First some option will offer this param and is in your param option to look for and is toolpath type dependent. Basically, you pick the diameter you want near plunging tool options and you can't miss it. If it is not there mean that toolpath it doesn't offer.
