I am adding a weight column in EMX BOM,
it is not getting the weight values even I refresh (Recalculate option) it.
Please find the attached screenshot.
Try setting EMX config option RECALC_SIZE_WHEN_OPEN_BOM as Yes
Somehow images attached are not loading.. try re attaching the images.
No luck, still unable to download..
You may check earlier post which has link to download tutorial for EMX.
https://community.ptc.com/t5/Manufacturing/EMX-bom-automation/m-p/604496#M4432
Done Sir.!!
Thank you.
I attached a sample BOM.
