Add Datum Axis for all the Holes in Parts built from Neutral Files
abolovan
Hello all,
I'm looking for an application that will add datum axis for all the holes in a part generated via importing neutral files.
We use these parts for programming (Pro/NC) - mostly plates with lots of holes on all faces.
We have a large library of UDFS built for native Pro/E files and they ask for axis selection, therefore it would save a lot of time to prepare these parts and add all the axis before working on the manufacturing file.
Any suggestion is appreciated,
Thanks a lot,
Anca
TomU
(To:abolovan)
There is a free Toolkit application called "AutoAxis" that will do what you're looking for.  I haven't used it since back on Wildfire 2, but it looks like it's still available.  Take a look at these links:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS48511
AutoAxis Windows 7 64bit
TomU
(To:abolovan)
thien94qn
3-Visitor
(To:TomU)
Can someone of you, share this AutoAxis compiled application?
Thank you very much in advance.
My email thien94qn@gmail.com
can you share me. I need it very much. thank you, my gmail phucloi.2311@gmail.com
TomU
(To:abolovan)
By the way, here is a nice guide on how to install it:
http://www.codexcreo.com/setup_use_of_autoaxis.pdf
Brilliant!!! It’s exactly what I was looking for. Actually is even more because it's grouping the axis based on diameter
Thank you so much, Anca
