{Blank Subject 2011-03-03}
How do I update my g-post for WF4 Pro-man?
Byron Taylor
Coordinator/Programmer
Danfoss Commercial Compressors
One Scroll Drive
Arkadelphia, AR 71923
E-mail: byron.taylor@scrolltech.com
Tel.:870-246-0750
8 REPLIES 8
Which Pro/E version are you using with it?
workpiece to wireframe..
Good morning guys. Is there a config option to turn the Workpiece to
wireframe instead of translucent?
Thanks.
Son Nguyen
Great Plains Mfg.
108 W. 2nd Street
Assaria, KS. 67416
785-667-7763 ext. 3477
Byron,
What are you trying to update your G-Post to (Version #)? Every new
version of Pro/NC swill have a newer version of G-Post. I think WF4 had
version 6.1 of G-Post.
Fred Nemecek
Austin N.C., Inc.
512/458-1112 x19
_____
Good afternoon,
You can use the "Style" functions in the view manager to set the display options for individual components in your assembly.
[View], [View Manger]
[Style] tab
[New] - create a name
[Show] tab
Select display choice, and components to apply it to.
Dave Ford
NC Programming Mgr.
G.W. Lisk Co.
Clifton Springs, NY 14432
(315) 462-4381
P Please consider the environment before printing this email - be green, keep it on the screen!
That was cool Dave!
Learned one more thing here... a good one...
Son, did you consider to submit an enhancement request to allow this in a config.pro option?
Tks!
Daniel!
Since Wildfire 4.0 you can use theView / Display Style / options. You must
select the wp partbefore using the command otherwise the command is grayed out.
David Brainsky
Chula Vista, Ca. 91910
email: -
Cell PH:619-253-5137
RE: workpiece to wireframe..
There's also this config.pro option: mfg_workpiece_transparency 0.5
This allows you to control the degree of transparency applied to Workpiece.
In Reply to David Ford:
Good afternoon,
[Style] tab
[Show] tab
Dave Ford
NC Programming Mgr.
G.W. Lisk Co.
(315) 462-4381
I knew about the mfg_workpiece_transparency but did not connect that with Son's request...
Sorry...
