For example, I would like "COORDINATE_OUTPUT" to default to SEQUENCE_SYS instead of the current MACHINE_SYS every time I make a new tool path.
Also, is there a way to custom populate the quick parameter options under the "parameter" tab? Common used parameters such as FIXT_OFFSET_REG used to set your G54-59, should be readily available, and I would not have to open the advanced parameter to access it. Any way to do this?
Hi Neal
You can modify site files for default parameters for all type of sequences & setup the default site files in your manufacturing file.
All the new sequences created after retrieving & setting the new site file will use the parameters from the given site file, for existing sequences you can go to edit parameters>edit>Inherit from site>
You will need separate site files for milling, turning & holemaking sequences.
