Hai,
in EMX, during ejector pin placement, relief holes will cut only in one insert, this is causing issues when split inserts are available which is sharing same ejector pin holes. one of the example is Blade ejector pins. Please let me know is there any way to cut the ejector pin holes in all sharing inserts with out manual updation.
You can report the same to PTC technical support, sharing data with steps will help in investigation of this..
