Helical plunge?
SOLVED
Highlighted
Newbie
Helical plunge?
Hello guys
could someone tell me is there a way for the cutter to plunge in a helical way in trajectory miliing at a specified radius instead of plunging at 90degrees or ramping.
thanks for any help
michael
1 ACCEPTED SOLUTION
Highlighted
Re: Helical plunge?
Michael,
Here is a helical approach on a pocket. If this is what you are looking for. the helical approach has to be after the plunge move and the parameter angle is 720 to do 2 turns. The clearance distance, radius and angle are up to you. hope this helps.
Steve
Highlighted
Re: Helical plunge?
Michael,
What I do is make 2 datum planes. 1 labeled start which is a distance above the part to start off the work and 1 labeled depth which is a diatance below the part so the cutter goes all the way through.For me this is the fastest way to get the helical cut to start off the part. Maybe some one else has a better idea but this is how I do it at least on holes. If you are looking at random shapes there are options for helical entry available in trajectory milling also.
Steve
Highlighted
Re: Helical plunge?
Michael,
Steve
Highlighted
Re: Helical plunge?
Hi Steve
i think thats what im looking for will try it out when i get back to work.
thanks again
michael
