Hey Guys..
When i create a process dokument for our millingmachines , i use the "&mfg.oper.ncseq.z_min" parameter.
For 5ax milling i will like to output the "z_min" from the seq csys instead of the oper csys ?
I´ve tried remove and replace "oper" but all whitout luck 😞
Jesper
Try using
&mfg.actoper.ncseq.z_min
or
&mfg.actoper.ncseq.csys
Thanks a lot..
I´ve tried both , with no luck.
Any other suggestions ?
It looks like the tool travel envelope
X_MIN
X_MAX
Y_MIN
Y_MAX
Z_MIN
Z_MAX
is always computed from the MACH CSYS. perhaps there is a way create a user defined pararmeter that could extract the value you want. PTC support could help with that.
