I am trying to create a mapkey for saving out IGES files. I would like to have (under Options/Advanced) "Geometry and entity preferences" set to "Surfaces and Wireframe". Is there a config option available to do this?
Work around would be to make (2) mapkeys. The first one would change the settings to "Surfaces and Wireframe". The other would ignore this because once it has been changed in a session, it stays that way until the program is closed and reopened.
I found this, but it says that the status is "Deleted".
