Is there a parameter that can be added as a column in the model tree that will show each NC Sequence coordinate system used?
I don't know of any such column or whatnot to show which CSYS is used by a particular NC Sequence. I'd hoped that it might highlight the pertinent CSYS when I picked the NC Sequence from the model tree, but no such luck.
Guess the only way to be absolutely sure is the tedious Edit Definition nightmare.
The Process Manager will show which CSYS each sequence uses. Just enable the "Orientation" from the "Mfg Setup Items".
