I was wondering if Creo 1 can create a groove turning rough toolpath in one sequence like the .avi Mastercam file shows in the simulation. I have the Creo .avi attached also.
I am looking to rough turn the groove diameter a two different depths and I am also looking to have the first cut to be at a slow rate than the rest of the roughing cuts. The first cut is full tool width.
Thank You
There wee two things I needed to get multiple depths. One was to set the step depth and the other was to make sure the vertex arrows for the start and end of the profile were pointing the right way as shown in the attached .png file.
