creo, vericut integration
ptc-5461421
i'm little new to creo
so anybody plese explain me how i can integrate vericut into creo 2.0
i have already install both softwears but when i run nc check it gives "Application VERICUT_DLL is not available or supported on this platform."
1 ACCEPTED SOLUTION
thanks a lot Wheelsofsteel that works!!!!!
5 REPLIES 5
Wheelsofsteel
(To:ptc-5461421)
It sounds like you haven't installed the vericut option.
you need to run the set up disk again but select reconfigure.
when you come to this screen
select the customise option
then you need to search throught the opptions on this screen and selecet the vericut option to install
You need to complete the reconfig process, then you shoul have the Vericut.dll
Peter
I'm also having issues with vericut_DLL not available in my own laptop, and I don't know where to get the vericut application to install. Please how can I install the vericut application online in my laptop? Or how can I get the disk to install the vericut application in my laptop. Thank you
What version of Creo are you using? PTC dropped Vericut for Moduleworks.
https://community.ptc.com/t5/Additional-Creo-Questions/ModuleWorks-to-replace-Vericut/td-p/169907
Thank you dschenken, the version I am using is Pro Engineer wildfire 5.
