Flexible parameter preservation not retained in cabling manufacturing flat assembly.
When applying parameters (dimensions) to a flexible part in a cable assembly the part reverts back to the original state when flatting the cable assembly in manufacturing. Is there a way to preserve the flexible part parameters as in the cable assembly when flattening the assembly.
I have the same issue, did you ever get an answer?
