operation name in a manufacturing file
Participant
Hello
I am trying to use family table for manufacturing file. I would like to add different name for the machining operation when you activate an instance. For example, is it possible to add a global parameter named NUM_OP which is different for each instance (please look at the attached picture) and to add a relation to automatically rename the machining operation? Or is there another solution to realize this?
Many thanks for your help.
Guillaume
Re: operation name in a manufacturing file
Hello Guillaume, I'm trying to do the same thing. Have you found a solution ?
On peut parler en français si plus simple pour vous.
Bonjour
Je pense que je vais continuer en anglais pour obtenir un maximum de réponse.
No I didn't find solution for tis issue. But, to be honnest this project has been stopped for the moment and i didn't spend time to find a solution. I think, I will need to use a .bat file during the post-process to be able to put the name of opération I need.
Sorry not to be able to give you more details.
A+
