remove slice or region using Creo
hemsid
we moved from WF to Creo last year
I have many times used a feature in WF wherein if you are breaking the material in volume milling with a step depth, I would remove the last second slice so that the final cut will have the end mill below the end surface for clean cut
I somehow not able to find a option to do that in Creo
If somebody knows please help...
0 REPLIES 0
