volume trim
spooge
volume trim
i've been away from wf4 for a few years, been using wf2 at current employer....
back then i had no problem(s), but it seems my memory is fading.
i'm missing something.
using nc asm, assembles ref model, created workpiece, worcell...
1) i can't trim volume to ref_model
2) when i redifine volume and add protrusion, mill sequence igmores added protrusion.
thanks
NickMihelich
6-Contributor
(To:spooge)
can you attach a file?  Not sure why the sequence would not see the trim.
spooge
(To:spooge)
actually after creating the volume, the 'trim' option is shaded out.
i know i'm missing something
i'm using nc assembly not expert machinist.
the steps i used are:
create nc asm
add model(ref)
workpiece
create; workcell, operation.
