Hi All
Ever since we switched to Creo, I have had a problem with playing the path and displaying the manufacturing info window together. as shown below
As soon as you press the play button, or click on anything else, the window goes to the back.
this is a real pain, we need to have it fixed so that this window always stays in front, like back in Pro E, I heavly rely on this window for play back info .
Here a suggestion. combine the two windows into one interface, so the tool path info data is within the CL play path window.
Peter
Peter,
This is happening in more than just manufacturing.
See this discussion:
http://communities.ptc.com/message/193689#193689
Thanks, Dale
