Today one can paste selected objects directly into MS Word but not into MS Powerpoint for example. One selected object in Prime can be pasted directly into Powerpoint though, but that is too limiting.
Pasted objects from a Mathcad Prime worksheet should result in a vector graphic figure in the receiving software – as from MCD 15. Or rather, one should be given a choice of formats, as common in many Windows programs.
I realize that PTC has put a lot of effort into MCD Prime’s own report capabilities but I believe there is no way around the need of compiling reports in other software too.
