I found myself wanting to keep a log of different iterations through a worksheet. I had to jump through a number of hoops to get this to work. Adding APPENDTEXT and APPENDCSV functions would make this process much, much easier.
Ideally these functions would create the required file if it did not already exist, just as APPENDPRN does.
